milage or lack of it
Hi Guys
Thanks for the info on the diffs, ill try that out later. Now I have another question and its this. For ever I was getting 6 miles to the litre and for the last few tank fulls that i have checked I am only getting 4 miles to the litre. This is a drop of 33% which is very severe. Would it have anything to do with the clock not counting the real mileage any more because of the bigger tyres I put on a while back. I know the bigger tyres will effect the speedo a bit but will it also effect the milage count aswell. Could it be the injectors need cleaning and if so would this sudden drop in miles per litre because of the injectors be normal.
John C
92HDJ 80 1HDT Ireland
Letter content was scanned by WinAntiVirus 2005.
No threat detected.
Please visit www.winantivirus.com for more details.
John, changing the tyres for those of a larger diameter will affect your speedometer / mileometer readings and will make them read lower than before. A good way of checking this is if you knew the mileage ( as shown on your LC ) between two places, prior to changing the tyres, you do the same journey, note the difference and calculate the % age change.
This will account for some of your difference.
But ...............
Wider tyres =3D more drag =3D more fuel used.
You have also lifted the vehicle since you last checked things ?
Now you have more air resistance which =3D more fuel used.
Have a look at - Toyota Yaris Diesel !
Gareth Jones.
Hey Gareth
Thanks for all that bad news, is there anything that I can do to this
machine that will not come cback and bite me in the arse at some later date.
I have a couple mountain bikes out the back would it look funny with those
wheels on and also get a lowering kit aswell , that should do the job
nicely. Although when I come over to you lot to go playing in the mud I
might get stuck at the first little puddle, I suppose ill have to live with
it now GRRRRRR.
John C
----- Original Message -----
To: <[Email address removed]>
Sent: Friday, September 02, 2005 3:44 PM
Subject: Re: [ELCO] milage or lack of it
But ...............
Wider tyres = more drag = more fuel used.
Now you have more air resistance which = more fuel used.
Gareth Jones.
Checked by AVG Anti-Virus.
Version: 7.0.344 / Virus Database: 267.10.18/88 - Release Date: 01/09/2005
No threat detected.
John, I am not saying that the wider tyres and the lift kit are the ONLY reasons for a drop in fuel economy - but they definitely will be contributory factors. If the difference occured only after these changes then I can bet a pound to a penny - or your case a cent to a Euro - where my suspicions lie.
Gareth.
PS - get the bike out of the garden and get pedalling !
John,
In some instances the larger tyres will aid economy, particularly with
long motorway drives because you will be using lower revs at the sme
speed, although if you are trying to maintain the same acceleration,
etc on normal driving you will be using more juice because the larger
tyres will reduce the acceleration.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
John,
AdBlock Detected
