big-yin
- Oct 13, 2018
Afternoon
So after having BigGreen (99 4.2TDi Auto) on the ramp at work today I have a few things I'd like some advice on if that is OK.
On the front, both sides, there is a bit of play in the wheels so that is being looked at. In addition we noticed that where the U bend arm that meets the join which goes to the wheel it is weeping, top ball joint gaitor apparently. Sorry for trying to describe it, hope it makes sense:
Also the rear suspension is weeping. Does anyone know if you can just have them re-sealed or if you need to get new unit? Then it would be a question of how far before you'd be better replacing the AHC for something else...
Also needs a new tyre, which I knew, front discs/pads need replacing and rear silencer has a hole in it so will go look for straight pipe.
Work today being done is new brake fluid and rear diff fluid being done.
Thanks.
Thanks.
