- Jan 8, 2019
Firstly may I apologize with all the question but I've got a few more.
1) Am I correct that there isn't a courtesy light switch on the boot? so when you open the boot the rear cabin light doesn't come on? If that's the case I think I'm going to add one and a boot light as well.
2) How hard is it to replace the following dashboard bulb, as when I go over dumps it turns itself on and off
3) What do people use to glue back together plastics? as I've noticed the tab on my drives sidelight has snapped, so it's no longer screwed in just on the push in tab thing.
4) Am I ok to replace my indicators with LEDs or is the relay going to go mental and think a bulb is out like on the LandRover?
5) When I start my motor the voltage slowly climbs from just under 12ish volts to 14ish volts but it takes about 30 - 45 seconds, then holds around 14 until I blip the throttle. Surely it should jump to around 14ish straight away. I believe this is leading to all my warning lights being on until I blip the throttle.
6) Some of a bulb on the AC controls have stopped working when the lights come on, any good location to get replacements as it's really annoying.
7) Will a 33inch spare wheel fit underneath ?
Sorry for all the question, I'm sure I owe most of the people on the forum a few drinks for all the help. Remind me that if I ever make a meetup.
