diggerdave
- Oct 5, 2014
My 1KZ-TE with 182,000m idles fine in normal circumstances (although it can vary between 750 and 850rpm (always steady) depending on how hot/cold it is, which I don't see as a problem).
From time-to-time, only when in slow-moving traffic after a longish (1hr+) journey, the idle drops right down to around 400 to 500rpm when changing down the gears . It's only for a few moments but it almost stalls. I can't reproduce it when stationary, it seems to require the engine to be under load before dropping the clutch ready to change down. It never has stalled, but the whole car shakes as if its about to.
I thought I had cured it when the problem first happened a few months back by a combination of changing the fuel filter and disabling the EGR, but now the problem is back and I wonder if I really 'cured' it at all.
Altering the idle speed using the tiny screw on the throttle body doesn't have any effect on the problem.
The car uses no oil or water and starts and drives perfectly, engine serviced religiously every 4-5000m for the last 30,000m
Could this be a TPS issue? Fuel supply? A dodgy tank of diesel (I did fill up at a non-branded petrol station)?
Any ideas appreciated, please!
