I'm having an intermittent misfire like condition (except its a diesel, 1kzte) only when the engine has been running continously for a couple of hours. When the revs drop to idle it will run badly and blow smoke from the exhaust like fuel is being thrown into the exhaust. Turning the ignition off and back on again clears the problem and it will run normally then for another couple of hours.
Is this likely to be an injector fault? The ecu?
I'm thinking I should get a techstream cable and have a poke.
