Rummaging in my garage I noticed something that was a bit of a surprise on one of my spare OEM 16" wheels, so I compared it to some others:
the one on the left is how I thought all the 16" OEM wheels are made - very shallow almost none existent recess between the mounting holes but as you can see the one on the right has a deep recess that's the same as found on 18" OEM wheels ... A quick check and I have 6 like the one on the left and 4 like the one on the right It only matters if you like to play with spacers thinner than 30mm which means the wheel studs stick out past the spacer and need a recess in the wheel. I use 20mm spacers with my 18's, might give them a try with the recessed 16's now to stop them rubbing (I've checked they do fit, just need the right tyres on the right wheels )
Anyone else got recessed 16" wheels? I shall have to look out for at least one more if I do use the spacers so the spare could be used without removing the spacer.
