oil contaminatiopn
Hi Guys
Just had the engine oil analysis feedback and it appears that the oil is contaminated by water.
On checking it, its not coolant but fresh water cantamination.
So where could it get in, I have done no swimming in the cruiser and all hoses appear to be tight.
cheers
john 92HDJ 80 1HDT
John,
You don't say how much water, if a small amount it could be
condensation from inside the engine washing in to the oil. This will
get boiled out of the oil at operating temperatures on a good run but
if you have been doing lots of short journeys it does not have the
time to clear. Should you have a leak that is letting water in then it
will also let oil out and you would normally spot it.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Hi Clive
Thanks for the reply.
The amount is 0.85% which they concider important once its over 0.2%.
It just seems weird its coming up as fresh water as oppossed to coolant
which contains Clycol which is normal.
Where would water get in and oil leak out so I can look more percisely.
Whats the price of Diesel now in the UK.
John 92HDJ 80 1HDT
John,
About =A31-08
Clive Marks
Where are you buying your diesel - here in the cotswolds it's up to =A31.28 /litre
Julian Voelcker
07971 540362
[Email address removed]
Julian,
It has been a while since I took any notice.
Clive Marks
Sorry, I blinked, it's now =A31.30.9 per litre!
Regards
Julian
Email: [Email address removed]
Mobile:=A0+44 (0)7971 540 362
Varies a lot I paid =A31-25 on the A14 near Cambridge last night but have seen
it for =A31-30 and =A31-23, in an 80 litre tank that=92s a big variation.
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
-----Original Message-----
Behalf Of Julian A.R. Voelcker
Sent: 22 May 2008 07:31
To: [Email address removed]
Subject: RE: [ELCO] oil contaminatiopn
Regards
Julian
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.21/1457 - Release Date: 20/05/2008
16:45
Checked by AVG.
16:45
