Lorin
- Mar 28, 2010
I've recently routed both the diffs and the gearbox breather into one tube and plumbed it into the side of the airbox (thereby effectively breathing from the top of the snorkel). However, on checking if any water got into the airbox after Mondays Salisbury Plain outing (which it didn't), I found a reasonable amount of oil in the bottom of the airbox. I'm assuming this can only have come from my breather and is therefore either gearbox oil, diff oil, or a mix of both.
Any ideas if this indicates anything I should be concerned about?
All oils are new (less than two weeks since replacing) and all breather lines were 100% clear before Monday's outing. If nothing to bother about I'll simply disconnect at the original breathers and blow any excess oil out to clear the breathers.
