oil stain
Hi Guys
Ah it has been way too quiet of late so her goes with a question.
I had to check under the bonnet today because of a problem. More about that later.
I found a new oil stain on the large hose leading from the air filter housing to the turbo.
Its just a little oil stain at the joint nearer the housing.
I checked inside the filter housing and there is only a little at the bottom where the hole is.
I checked in the pipe and.its only a little moist.
So what could be the cause of the oil stain.
cheers
john 92HDJ 80 1HDT
Hi John,
I am not very good with engines and turbo's, but I would suspect the oil is
from the Turbo.
Now it could be normal as there is always some oily mist from the turbo.
If its excessive amounts then it would suggest the turbo seals/bearings are
on the way out.
Does it smoke a lot or the turbo whistle excessively.
I would not have expected to see oil spilling into the air filter housing?
But I am NO expert.
Behalf Of john byrne
Sent: 18 December 2007 19:45
To: [Email address removed]
Subject: [ELCO] oil stain
Hi Guys
later.
where the hole is.
cheers
john 92HDJ 80 1HDT
John,
The breather from the top of the egine runs in to the pipe going from the air filter housing to the turbo - the oil you are seeing is probably from the oily air from the engine.
If there is a stain on the outside of the hose, the may be a small leak there or if it is on a joint, the joint may be loose.
Hope that helps.
07971 540362
Just had this and Martin's reply but no original question from John.
My server our Elco? Who knows...
Jeremy
On 19/12/07 18:24, "Julian A.R. Voelcker" <[Email address removed]> wrote:
Jeremy Llewellyn-Jones
Mob: 07831 458 793
This is getting a little silly, I know that the server has had problems, but this is too much.
I'll shift the list over to another server over the Xmas break.
07971 540362
Hey Julian
Did I break this too.
john 92HDJ 80 1HDT
----- Original Message -----
From: "Julian A.R. Voelcker" <[Email address removed]>
To: <[Email address removed]>
Sent: Thursday, December 20, 2007 4:58 AM
Subject: RE: [ELCO] oil stain
this is too much.
07971 540362
Julian, I am still not getting your messages, only replies to them?
Chas
Sent: Thursday, December 20, 2007 7:28 AM
Subject: Re: [ELCO] oil stain
AdBlock Detected
