Hello,
Just wanted to find out if anyone has had the same problem.
I had my full suspension OME kit fitted by a well known Co in Oxfordshire. It was fine for about 9 months then, I started to hear noises, rattles and squeaks from the driver side.
I took the vehicle to many different mechanical gurus, and they even tested it on one of these machines which do a vibration and bump test while under the vehicle and they found nothing.
2 months ago my son bounced the driver side of the veh up and down and we saw that the bolt on the shock moved up and down with the rocking movement. The other side did not.
So, when we spoke to the Gurus (Dont want to name names) they said the lower bush on the shock was gone.
To order it, was told it would take 12 weeks as its an ARB part.
So yesterday, I figured that if the bush was gone, the shock would move but the bolt holding it should'nt, so, took the wheel off and with a size 19 spanner and socket, tried to tighten it and guess what, it was so loose that I could tighten it with the spanner.
Now, magically all the noises disapeared and I dont need a lower bush as it was the loose bolt that was the culprit.
Is this common? has anyone also had this problem, is there like a recomendation as to how often one should check for loose Old Man Emu shocks?
You have been informed, any rattles and squeaks etc, pls do check loose shocks.
