- Feb 24, 2010
On a recent trip to Morocco where temperatures were reaching 57C my 80 was drinking water like a steam train, 1 liter every 100 or so miles
We started off from the UK with a 200 mile stretch to the the ferry port, all was fine.
Next was a 680 mile day down through Spain, all was fine in the North but, as we were about 100 miles from the Southern tip the temp gauge started climbing.
Lifting the hood revealed a full/overflowing header tank and the breather pipe was bubbling away. Once I had carefully released the rad filler cap, which took 3-4 minutes, it was evident that the water was boiling. I emptied the contents of the header tank back into the rad and then topped up the rad and header tank with more water (1 liter).
For the next 2 weeks this was a regular occurrence, which seemed to be worse when there were many hills or tough sand crossing involved.
After a quick phone call to Julian I realised the over heating issue was being caused by me fitting a eBay single core rad before the trip. I didn't realise the standard rad is 3 core and the replacement was supposed to be to OEM spec. With the autobox cooler in the bottom of the rad it was also causing the water temp to rise with the difficult terrain
Checking the rad every 100 miles kept the problem at bay but, when it wasn't boiling there appeared to be 'Black grit' around the rad filler. It doesn't appear to be metalic as it is totally Black with a sand like texture... any ideas what it is?
This was an all too regular occurance which, in the presence of a Green Oval, was bloody embarrassing.
