Overland Prep Help / Checks- Landcruiser Colorado 98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Martin,
The at's are a good tyre and probably a sound investment. I am
not sure about the suspension upgrade, the Colorado has IFS, or the
one I had did (maybe the 98 is different). Unless the springs or
shocks are worn you could probably leave it alone. The weight that you
may carry might make suspension a must though. My Colorado had a
certain amount of underbody protection as standard, not steel but OK.
I am a bit cynical of battery upgrades, far more important to have a
pair of batteries that are in good condition, a pair of quality 85 AH
batteries would do. A roof rack will probably be a neccesity but it
can be a cheaper one, try to put only lighter stuff on it, it is far
too easy to make the vehicle top heavy, or to take too much because
you have the room. A breather extension is an easy 'do it yourself'
job. A snorkel would be a good idea. Would a sunshade do instead of an
awning? Are you going to need a roof tent?, to get away from animals
that may be a problem.
A few years ago people used to buy a 4x4, service it and travel.
Only in recent years has the industry decided that you need this and
that for a proper journey. While some of it is good stuff there is a
lot of hype.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
