Matt Vee
- Jul 22, 2019
Does anyone know if the pedders lift kit is literally a longer strut length or does the strut actually have longer travel? I noticed the active coil count is the same as stock so am assuming it's the same travel shock stroke unless the spring rate is different.
Do the springs have a higher, lower or the same rate as the toyota stock ones?
Thanks in advance.
Thanks in advance.
