Howmanygoes
- Jan 14, 2019
For my first major mechanical upgrade I am looking at suspension (to tie in with new rubber, see my other post)
Currently considering the Pedders 45mm lift kit at circa £700, the iron man foam cell pro which works out around £1k, OME, 2” lift kit works out about £1.1k
Some of the kits recommend diff drop brackets, I presume this is to prolong the life of the diff? Questions,
1) anyone have direct experience with either of the kits, thoughts?
2) is the diff drop necessary?
3) Will the diff drop need alternative under protection.
4) the pedders kit has a support bracket for The TBs, should I consider these as an extra with the other kits?
4) Anything else I should consider?
Thanks in advance
Thanks in advance
