------_=_NextPart_002_01C6AB11.36783D62
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
A Picture
As you can see the original needed replacing. The problem with the new
system is the bracket of the header pipe (bottom of picture) which is
not long enough to meet the mounting point. The boys will cut a piece
of stainless stock to fit and then bolt it all together and maybe it
will work.
You can see the tarnishing on the welds of the top box.
All the best
Simon
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2900.2912" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D449165208-19072006>A
Picture</SPAN></FONT></DIV>
class=3D449165208-19072006></SPAN></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D449165208-19072006>As you can see the
original needed replacing. The problem with the new system is the
bracket of the header pipe (bottom of picture) which is not long enough to meet
the mounting point. The boys will cut a piece of stainless stock to fit
and then bolt it all together and maybe it will work.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D449165208-19072006>You can see the
tarnishing on the welds of the top box. </SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D449165208-19072006>All the
best</SPAN></FONT></DIV>
class=3D449165208-19072006>Simon</SPAN></FONT></DIV></BODY></HTML>
------_=_NextPart_002_01C6AB11.36783D62--
charset="us-ascii"
A Picture
will work.
All the best
Simon
charset="us-ascii"
<HTML><HEAD>
<BODY>
