Managed to get some photos today and apologies as the trucks a little dirty at the moment - heavy rain and mud wash outs!
Start with a couple of diagrams;
2nd. The pump and bracket which includes the tensioner
The lower shaft fits to the 40 column joint
the steering box mounts close to the rad and you may have to ease the inner wing
The pulley sits out from the alternator belt and clears the fan but you will have to loose the cowl if you have one
The reservoir sits at the highest point in the system - on the rad top mount on the pump side.
The pump belt adjuster is part of the bracket. The pump mounts on the opposite side of the engine to the steering box. My hi-pressure hoses run under the radiator cage. Pressure is around 1150psi so use the proper hoses.
in the following pic the hose you see is the low pressure res-pump and the return pipe is also low pressure.
When all the track bars etc are on you will not be able to run a pto winch.
In this photo you can see the low pressure return line and the track bars.
If yo decide to go this route make sure the set up from a 60 series is post '85 as the pump design changed and the early ones are no longer available (ask me how I know!). You are probably best getting all this kit from Australia as they are RHD. If the stuff is second hand get the VIN number from the donor vehicle, if possible. Euro4x4 also supply the parts for RHD and export worldwide.
Hope this helps and if you need more info, just ask.
Rodger
