Beau
- Jan 28, 2011
Here's the trouble...
On some mornings on first start up the engine turns over slow (half the usual speed) but fires up within couple seconds like normal. I thought the batteries were on there way out so got them checked. One was good but not 100% so was replaced under warranty. A few days later I had the same problem again.
I'm not sure on this, but I do believe it has occurred on cooler days rather than the hot days. By cool I mean around 15 degrees. I've not had a problem with it starting back up during the day. It's happened about three time now within the past month and it's only in the morning. What I'm going to try next when the slow start occurs is to switch it off back instantly, and crank it again and see what happens.
Is there a possibility the starter itself is on it's way out? It's the original starter so is a good 20 years old. I've only ever replaced the solenoid contacts on it.
