Programming keys and locking remotes?
Hi all,
After reading a horror story on this very forum about the costs involved
if you lose your keys, I thought I'd better get a spare remote control
for the alarm/central locking and a spare key, as I only have one of
each.
My car is a UK spec '97 diesel and the key apparently has a transponder
in it as an extra security device. Certainly, it's a different key
blank to my '95 petrol.
Anyway, Toyota tell me that I'll need to book my car in with them for
them to programme the new key and remote to be the same as my current
ones - and therefore work. However, I'm half sure I read somewhere that
this can be done at home with a complicated sequence of turning the
ignition on and off etc..
Does anyone know if this work can be done DIY? I'm semi-allergic to
Toyota workshop prices.
Cheers - Andy
Andy Bell
t: 07966 875 146
m: <mailto:[Email address removed]> [Email address removed]
On 8/3/05, aclbell <[Email address removed]> wrote:
Andy,
Can't help with the OEM security system - I got rid of it years ago
because by installing my own system at least I know how it works and I
don't want to support Toyota dealers' extravagant lifestyles.
If you knew the model and manufacturer of your alarm maybe you could
approach them directly for technical help.
You could try getting a new key from a key cutting outlet. If it has
straight edges with wavy grooves on each flat side, it needs to be cut
by a laser machine. There's an outlet near Paddington Station that can
do this.
Rgds,
Roman (London, UK)
'92 HDJ80
On 3/8/05 13:57, "Roman" <[Email address removed]> wrote:
My keys are like this and I want to cut a third. Any idea who the people in
Paddington are please?
Jeremy
Jeremy Llewellyn-Jones
Mob: 07831 458 793
I have scans, etc of manuals for a couple of the LC alarms, if you
could find out which one you have I could send the stuff over.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Thanks Roman. I know Praed st well... I spent 80 consecutive days filming in
St. Mary's hospital.
I may have found a local firm but if not I will head to Paddington.
Jeremy
Mob: 07831 458 793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