MarkW
- Aug 20, 2014
Got a bit of a braking problem with the truck pulling to the right when slowing above about 40mph.
It started on my last trip after changing the front brake pads on the DS and had since been MOT'd ok.
Front calipers have been rebuilt, new pads and discs as well. Rear drivers side was swapped for a 2nd hand caliper early in the year. Lower suspension arm bushes are good and MOT had an advisory for the drivers track rod end, nothing else suspension bush wise.
The rear left caliper is manky and needs sorting out, but is there anything else I should look at as the cause?
