Radiator pipes!
So far I haven’t needed any new pipes but have been looking around. Saw those and they sound good but I have learnt to stick to Toyota parts unless impossible to find. When I cant get those then terrain tamer is 2nd choice. While these are usually a bit more expensive, i see it as a long term advantage in not needing to repeat the process
Have just bought a set, fitted the upper and lower hoses and they are close to be being right, the main air inlet one was way to long and getting it on air cleaner side was a struggle, the rest of the kit that came wasn't right and does need fettling, I have told the guy and he says he will put it right but a couple of pipes are definitely not right or close. with that said, not bad for aftermarket kit but it is not a complete kit. will know more when I get round to fitting the rest.
