Rear Diff lock & the ABS.........
sae70
.......Why does the ECU turn off the ABS when the rear diff lock is engaged :?: :)
Because it has no way of modulating a single wheel when the diff locked.
Ian
Ah :D Of course :)
So what happens to those who fit after market diff locks that also have ABS then :?:
Normally you would use the difflocks in low range, so ABS would (normally) be switched off then. So it's unlikely to be an issue.
