Knucklehead
- May 28, 2013
Guys, hoping can get some advice.
Long story short, I managed to track down an ever increasing loss of coolant.
Turned out when the garage fitted my g'box back after a new clutch couple of years ago they managed to bend the end of the breather up against the metal rear heater hose behind the manifold and its wore a hole in the pipe. Seems every time I am rarely forced to use garages I end up with more problems than I started with!
Looking the engine bay, I can see the coolant pipe that is leaking running down the firewall behind the exhaust manifold and the second pipe seems to be on the other side of the block near a 'U' type bend running down the firewall?
Would really appreciate if anybody could advise on quick engine bypass that's not permanent as plan to cut out the damaged metal pipe section when get time as the rest of the pipework seems sound. Would be great if have any pics/parts used.
Cheers,
Dave.
Cheers,
Dave.
