I decided to test how 'limited' my rear LSD was today, my 80 is a early 92 JDM import.
After jacking one rear wheel off the ground, I selected D and let my foot off the brake. At this point the lifted wheel just span with very little attempt to move my truck. I engaged the center diff and tried again, sure enough she tried to drive off the jack, so at least I know the center diff works.
Is this the norm or should my truck have made an attempt to move without the center diff locked?
If this is normal, I suspect that I may be on the lookout for a UK spec rear axle. Are all rear diff ratios the same and can the locker be actuated via a simple on/off switch if wired correctly?
