Matt Wright
Hi guys
Ruby arrived in good condition bar a couple rust spots and questionable modifications.. I'm busy working through all of them as time and resources permit. One thing that had to be done for security reasons and the fact that I had a big door in my boot was to swap the existing "rusted through in 3 places" rear upper door with a spare that I was given with the truck Handy!
I was told by someone who drives a truck which has part of the name M_X_Y! that it was a half hour job. Maybe for a trained professional so here's my account of what I did, what I learnt and the end result.
Rear door swap out Goals / Plan / Method :
Goal : Swap out whole door but migrate all existing custom parts incl lock, wiper and glass safely (alone in the cold outside using very basic hand tools )
Plan : Unbolt old door, put it next to new door, take photos of key areas to aid re-assembly, remove all parts, put them in the new door, re-bolt back on..
Method and learning :
The door came off easily bolt wise. It would definitely be very very useful to have a helper who can hold the door so you don't have to work like an octopus when it comes loose. I removed the side bolts first so it was eventually hanging / propped up on a box by 2 of the top bolts, one on each side.
Got them outside and ready to disassemble. Enter first issue : RUST.
I'm no stranger to working wit hrusty bolts, but this was ridiculous. The bolts on the inside were mint condition, but anything poking through the door no longer resembled it's original state. Be gentle..
Note *** Take more photos than I did from multiple angles inside and out the door. I took 12 and it still had me guessing on parts of the lock..
I got everything out bar the wiper sheeth (explain later)
Big thank you to Karl for his tips on how to remove the glass and more importantly, how to put it back in!! Oh and Chris for general tips but he was busy playing with his new tools
The tricky parts were getting the glass out. This was simply because it's not just popped in, it's glued in.. Run a screw driver around the edges carefully but with enough force to break through the glue. If you miss spots, it's very difficult to get it out.
Tips :
If your new door has any rust signs, paint it before you start the job using Kurust or something similar. It really helps if you get it all done properly so you're not working with paint moving around in the door at re-assembly time. This is also critical for prolonging the new door's lifespan (as I really don't feel like doing this again!). Paint the parts you can see. Allow to dry. Then turn it upside down and you'll find a bunch of spots you didn't see before! Least I did
The Windscreen wiper part that sticks through the door slides out so just pull it once you've gotten the blade off. It doesn't screw out.
The lock is delicate so treat it with care. It pushes out easily once the nut on the side of it is removed AND the metal slide in spring mount. Pull the tab and it should slide down, freeing up the lock. No need to push and pull or use screwdrivers on the outside which was I thought I might have to do.
The locking mechanism has different colour coded, parts of differing thicknesses - take note of these
The windscreen wiper arm comes off ok. Mine was covered in rust dust as there are magnets inside it, brush it off once it's out.
Re-assembly was relatively smooth but it was freezing cold by this time and my hands were numb. That didn't help!
I started with the lock as it's the trickiest part, then the windscreen wiper and then the bolt on bits
Once it is reassembled, get help putting it back on. It's simple if you have someone holding it. I used boxes which worked but is risky as it might fall and render all the work useless I had my missus help but at 5"2, she did a valient job but I resorted to boxes in the end
One thing ot note is that the bolts need to be straight / put it on and then straighten it. Mine was protruding slightly on the right side after the first go.
That's it.
3 outstanding items that I'd appreciate ideas on are :
1) You'll see a bolt in pictures 4,5,6 which is a 27 socket nut on the outside that holds on the "wiper sheeth" that it sticks through. Try as I did I can't get it out. Anyone now if Toyota sells this as a part? I will call but they always ask for a part number and are pretty unhelpful if you don't have one This would be a lot easier than wrenching it out. It's REALLY stuck on there. Rust.
2) The water pipes are connected up correctly but when I press the wiper arm to spray water, it sprays out the side of the truck?! A little did come through the jet but it looks like it's getting lost somewhere in the roof Any ideas or is it "remove door surround panels and then look inside the roof lining?" I've not been in there before and would prefer to not tear anything if I can avoid it. It's a bit frail..
3) The lock has a type of horse shoe slide on ring on the end of it that holds on one of the arms joined to the locking mechanism. This is to enable the key to turn and open the lock. The end of mine is worn off and I can't get the circular washer on the end of it securely given that it has force applied to it when the key is turned. Any ideas?
And finally, some pictures..
Where I work
An example of a close up - good but only from 1 angle.. Take multi angles
The 27 socket and corresponding inside (with bent arm piece but it'll bend back. Again, plan A is to just put a new one in. Hope they are £1 not £50!)
Shiny NO RUST left hand side
Shiny NO RUST right hand side
Tips :
That's it.
Where I work
