UPDATE:
Got "The Lorry" back from the shop yesterday.
Work performed...
1. 5000km Oil and filter change
2. Remove original brake vacuum booster and replace with dual diaphragm brake vacuum booster.
3. Perform complete front and rear differential overhauls, new carrier bearings, new pinion bearings, new oil seal and set crownwheel and pinion wear pattern and backlash.
4. Install Harrop E-Lockers in both front and rear differentials
5. Replace existing clutch with Safari Heavy duty clutch plate, pressure plate, thrust bearing, spigot bearing and rear crank oil seal. Skim and Dynamically balance flywheel together with pressure and clutch plate.
6. Do some electrickery work that required attention.
None of this work was required as a result of performance or breakdown requirements, but rather as a result of things / improvements that I wanted to do to improve the overall reliability and drivability of The Lorry. With the following exceptions; a] the existing clutch was shuddering violently due to having developed high spots on flywheel. b} evidence of past water ingestion into diffs was evident from some diff components showing rust residue.
New driving impressions;
as a result of the dynamic balancing of the clutch components and flywheel the driving experience is now really noticeably super smooth and the difference for the better is almost unbelievable.
and,,,,, for all you 70 series drivers, a recommendation, one of the best improvements you will do for the safety of you and your trucks, is to upgrade the brakes, even if you do only the dual diaphragm vacuum booster and stainless steel braided hoses, but what I have done over the past year was the full Monty - Powerbrake front disk rotors and pads, TT heavy duty rear disk rotors and pads, stainless steel braided brake hoses, dual diaphragm vacuum booster
The improvement in braking performance is absolutely exceptional.
Now - the new remote reservoir DCS suspension is being fitted on Monday - feedback on this to follow.
