sam89
- May 6, 2018
Hi all i am a new member and am currently in the process of buying a 105 series. I stumbled across an add for one (1999 105 with 480xxxkm) that has had alot of money spent on everything imaginable and the car is immaculate. however it has just had a full rebuild (50km on clock since) lots of money spent but i am unsure how reliable re built motors are? the owner seems like a very reasonable guy and took me to the workshop who assembled the motor aswell as there is a 12month transferable warranty. the only reason he is selling is he doesnt use it as a 4x4 anymore is quite well off and doesnt wanna see it go to waste. I am just not 100% on how reliable and how much life i will get out of the rebuild.
the owner had the rebuild done with a full turbo kit i.e pistons, rings all set up to run the aftermarket turbo (gturbo badboy extreme) fitted. the boost has been re calibrated to 10psi and the 12mm pump had also been calibrated back to factory specs for the run in process.
i have no doubt he has done everything correctly i just want some honest opinions on buying rebuilt 1hz motors
cheers for any advice thanks, sam
