Hi guys,
I am after an inexpensive 12V portable air compressor to have in my 80-Series, this will have two main roles as follows:
- Inflate the Polyair airbag helper springs fitted to my rear axle, to control loads
- Emergency tyre inflation (I do not anticipate airing down tyres and pumping back up again regularly, but would be helpful to have an on-board air supply if we had a slow puncture, for instance, or needed to air-down in a difficult situation)
The key things for me are reliability, an accurate pressure gauge, and cost. I was looking at something like this TMAX item: http://www.devon4x4.com/index.php?p...roduct_id=315&option=com_virtuemart&Itemid=14 or http://www.mm-4x4.com/t-max-heavy-duty-portable-air-compressor-2929-p.asp , or a VIAIR item such as this: http://www.mattsavage.com/acatalog/85P-compressor-00088.html
If I can keep the spend to around £50 that would be great, as I really don't think I'll use it often! Also, do most of these come with a DIN connector, or battery clamps, or both?
Any suggestions/recommendations welcome!
