THL
- Nov 6, 2017
Starting the handbrake refurb and have got as far as removing the caliper. I’m only wanting to have a look under the rotor at the parts that might need replacing so I want to avoid taking the caliper apart. Can I remove the caliper by undoing the two 17mm bolts from the backing plate or do I need to remove the two caliper pins first and then the 17mm bolts?
thanks
thanks
