Neil Hicking
- Jun 13, 2013
Hi,
getting a bit desperate with this one!!!!
Trying to replace the pipe from the top of the rear shocker that goes to the AHC globe - its corroded and leaking. Can't get to the nuts easily that hold the pipe flange to the subframe where it fits onto the top of the shocker. These nuts are seized on and probably will snap if forced.
Is there an easier way to access these nuts? We are looking at cutting the floor out, to get from the inside of the car, but there are cables and pipes in the way. Yes this is a bastard job indeed. I read somewhere you can get from under the wheel arch but this doesn't work.
Any help or advice most appreciated.
