- Sep 28, 2016
Morning folks, while trying to diagnose a charging issue on my 80 I discovered the DS negative terminal clamp was badly cracked, and needs replacing.
I would like to replace this with a clamp that provides additional posts for adding accessories.
My questions are:
Rosy
My questions are:
- Has anyone replaced the OEM clamp with something similar, if so what clamp would they recommend.
- Is there any reason Toyota decided to use this "sealed" type clamp for the negative side rather than the post type they use for both positive terminals?
- Is there anything I should be wary of if switching from the current type to a post type clamp?
Rosy
