Replacing calliper
Hi Guys,This may seem a silly question but is it correct that there is only one rubber slider pin cover ( probably the wrong terminology) and yet there are the two pins as per this Slider kit , thanks
https://www.ebay.co.uk/itm/TOYOTA-LANDCRUISER-J120-2003-2009-2x-REAR-BRAKE-CALIPER-SLIDER-PINS-BCF1418BX2/231705833651?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
PS this is kit is for both rear calipers
Yes, there's only a slider cover on the bottom of the caliper. Top of the caliper has one of these. https://www.ks-international.com/to...2002/brakes/dust-boot-rear-brake-caliper.html
They *tend* not to fall apart as much.
Thanks Rob that puts my mind at rest.
Can you tell me if the top and bottom sliders are different,I have looked at a couple of exploded drawings and although the drawing are not particularly detailed it looks as though they may be slightly different.
Thanks again Rob,this is the set I have ordered,I'm assuming its the full set of correct pins,sleeve and dust boot for both rear calipers.
Regards Matthew
PS this was the drawing I was referring to
https://partsouq.com/en/catalog/toyota/part?catalog=GR&model_code=HZJ105L-GCMNS&group=4707
Likely the same part but that's not
Regards Matthew
Problem is that's a diagram from a 105 and you have a 120; well I assume you have as you're posting in the 120 forum :). Yours should be more like this one https://partsouq.com/en/catalog/toyota/part?catalog=GR&model_code=KDJ120R-GKAGYQ&group=4707
Different calipers on a 105, although same sliding bolts. I've DM'd you to sort you out with more appropriate diagrams.
