You should be fine. Best advice would be to test the fuel for:
Soap content 100ppm - 200ppm is acceptable (ASTM is 50ppm)
Glycerin
Methanol content
Water very low ppm
Monoglycerides / Tryglycerides
Soap, Glycerin and Methanol are the most important. Also worth understanding what level the fuel is filtered to.
There are some great biodiesel producers out there, but also a noticeable minority who have been less rigorous. The latter have caused damage to mainly injection pumps and injectors. Personally, I've never put a litre of anyone else's fuel in my LC. I brew my own, test at every stage and use a centrifuge and polish pots on final polish to ensure that anything not caught during the wash and dry process is caught. So the fuel has very low soaps, almost zero water ppm, post production residues such as mono/tryglycerides are caught and fuel is cleaned down to 0.3 micron.
Guys on the bio forum have called my final polish 'exotic', but it ensures no problems. The IP on the LC has an internal finger filter that will plug up with contaminants such as soaps that will pass through the fuel filter.
Landcruisers are fine on good fuel, if you want a car that will run on variable quality fuel, old Citroens and VW's pre-common rail are not at all fussy. Virtually all diesels will run on well made BD (Rule of thumb - if it has a DPF or similar, do a bypass and delete the regeneration instructions from the ECU).
