Hi guys - added a checp water temperature gauge to mine last week and getting what I think is a high reading. Once warm its at just over 100C or with the heaters fully on for a few mins its about 95C.
I though it might be the gauge so swapped with both a spare of mine and a friends and all shoing the same temperatue.
Then though it could be the sender so swapped that with another one and still the same temperature.
Also run seperate lives and earths direct from the battery and still the same so im ruling out the gauge being dodgy and thinking im running slightly hot.
Dropped the coolant out of it tonight and it just seemed like water in there. Chucked a hose though the radiator and seems to flow freely, also put it down the upper engine hose and gently trickles slowly out the bottom (slowly due to the thermostat being in the way im assuming).
Bled it all with the heater on hot and the front end a few feet up in the air until there were no more bubbles and im still running at the same temps !
The only things I can think of that are left is the viscous fan as it does not really roar unless you have the revs quite high or maybe the water pump is not circulating it well enough ?
The gauge is measuring from the middle of the top radiator hose so am I reading in the right place ?
Also it only seems to be the top third of the radiator that actually seems to have any heat in it - the lower two thirds and the bottom radiator hose are rather cool
Sorry for the mega long post !
