Dave Docwra
- Apr 24, 2010
There are to be some changes to the MOT test from 1st January 2012 which are being introduced in response to European Commission Directive 2010/48/EU of the 5th July 2010 and which will effect those with aftermarket HID headlights and remapped ECUs:
4.1.4 Compliance with requirements:
(a) Lamp, emitted colour, position or intensity not in accordance with the requirements
(b) Products on lens or light source which obviously reduce light intensity or change emitted colour
(c) Light source and lamp not compatible
4.1.5. Levelling devices (where mandatory):
(a) Device not operating.
(b) Manual device cannot be operated from driver’s seat.
4.1.6 Headlamp cleaning device (where mandatory):
For anyone with a remap, section 6.1.9 may be relevant.
6.1.9 Engine performance:
(a) Control unit illegal modified.
(b) Illegal engine modification.
(by 'illegal', it is assumed that they mean changed/programmed differently from OEM specifications)
There will also be a new check on the general condition of the wiring:
4.11. Electrical wiring
(a) Wiring insecure or not adequately secured.
(b) Wiring deteriorated.
(c) Damaged or deteriorated insulation
and on the function of airbag and seat belt pre-tensioner systems:
7.1.4. Safety belt Pre-tensioners:
Pre-tensioner obviously missing or not suitable with the vehicle.
7.1.5. Airbag:
(a) Airbags obviously missing or not suitable with the vehicle.
(b) Airbag obviously non-operative.
7.1.6. SRS Systems:
SRS MIL indicates any kind of failure of the system.
Some of the above won't be popular with some around here I know, but VOSA have confirmed that the necessary changes to the MOT test schedule will be introduced and from 1st January 2012 vehicles that fall foul of the new requirements will fail the test.
The biggest change is they will now be able to detect re-maps, and car will fail the MOT if this is the case.
One assumes this has been brought in because a lot of people who re-map their cars don't inform their insurance company.
7.1.5. Airbag:
7.1.6. SRS Systems:
