Split charging works!
Hi all,
As I was going away for a month I left my LC in a secure car park.
Secure or not, I preferred the alarm to be switched on. Upon returning
to the car I found the main batteries were nearly flat - the starter
solenoid would not even make a clicking sound.
It was late in the evening and not a soul in sight to help me jump the
starter from a spare battery (let alone two batteries in series!)
Option one - a long walk home to try again in the morning. Option two
- flick a switch on the dashbard to connect two spare DMS Red Top 30
batteries, start engine, drive home. Presto!
After wiring up my Hellroaring split charging system I ran only a
basic test on it. Now I am satisfied it works as promised.
Rgds,
Roman (London, UK)
'92 HDJ80
On 3/3/05 10:24 am, "Roman" <[Email address removed]> wrote:
Quick question...
How come the main batteries were nearly flat?
Jeremy Llewellyn-Jones
07831 458 793
Roman,
That must have been a relief but should the batteries have lasted a few
weeks without problems? Can you give details when you're settled in at home
on your split charging conversion?
Anthony
-----Original Message-----
Behalf Of Roman
Sent: 03 March 2005 10:24
To: [Email address removed]
Subject: [ELCO] Split charging works!
Hi all,
Rgds,
Roman (London, UK)
'92 HDJ80
Jeremy
They were drained by the alarm system, something you wouldn't notice
if you use the car every few days.
Rgds,
Roman (London, UK)
'92 HDJ80
On Thu, 03 Mar 2005 10:29:04 +0000, Jeremy Llewellyn-Jones
On Thu, 3 Mar 2005 10:29:25 -0000, Anthony Graham <[Email address removed]> wrote:
Anthony
Ideally, my batteries should provide 140 Ah but in real life I don't
expect full capacity after using them for two years. It's possible I
left another device on that added to current drain. I could upload a
pdf with the diagram but AFAIK we have no file storege at ELCO yet, or
do we?
Rgds,
Roman (London, UK)
'92 HDJ80
Roman,
Do you have then 4 batteries in your 80? What made you decide to add a
split charging system? I do not think the web site is up and running as yet.
Anthony
Behalf Of Roman
Sent: 03 March 2005 10:45
Subject: Re: [ELCO] Split charging works!
wrote:
home
Anthony
do we?
Rgds,
Roman (London, UK)
'92 HDJ80
Hi Roman,
Bung it my way and I will stick it on the server somewhere.
Mobile: 07971 540362
Hi Roman,
Thanks Julian,
It's not a problem at all. I just thought we already have this
facility but I've missed it.
I put the files on my web server:
http://www.zen59375.zen.co.uk/public
Rgds,
Roman (London, UK)
'92 HDJ80
On Thu, 03 Mar 2005 12:00:20 GMT, Julian Voelcker
I have a slightly different approach I'm still finishing - a single
110ah aux leisure battery split charged with all the accessories like
interior lights, power sockets, inverters, stereo, computer, alarm, CB
etc running off that.
I'm still in trouble if I leave the side lights on or something daft
like that but otherwise drain on the main batteries is 0.
This is a UK HDJ80 so dual batteries under the bonnet as standard which
I've left alone.
Best Regards,
Jon.
On Behalf Of Anthony Graham
Sent: 03 March 2005 10:49
Subject: RE: [ELCO] Split charging works!
Roman,
yet.
Anthony
On
Behalf Of Roman
wrote:
few
at
home
Anthony
do we?
Rgds,
Roman (London, UK)
'92 HDJ80
Roman,
I couldn't help noticing you have pins through the bonnet to hold it
down? Where did you get them from and what model are they? I need to do
that so I can remove the centre support from behind the grill to make
space.
Best Regards,
Jon.
On Behalf Of Roman
Sent: 03 March 2005 12:23
Thanks Julian,
Rgds,
Roman (London, UK)
'92 HDJ80
or
On Thu, 3 Mar 2005 12:30:22 -0000, Jon Wildsmith <[Email address removed]> wrote:
Jon,
That's obviously a different approach. I opted for an aux battery
(which if fact is divided into two smaller batteries) and using it as
a booster battery. This also means the OEM battery setup is left
alone. There are sttil more combinations possible.
Rgds,
Roman (London, UK)
'92 HDJ80
On Thu, 3 Mar 2005 12:34:55 -0000, Jon Wildsmith <[Email address removed]> wrote:
Jon,
I bought them from http://www.trackstore.co.uk
Get the stainless steel type as those made of aluminium have steel
parts that rust in no time.
Rgds,
Roman (London, UK)
'92 HDJ80
Thanks Roman, stainless steel ones on order.
Best Regards,
Jon.
On Behalf Of Roman
Sent: 03 March 2005 12:47
wrote:
do
Jon,
Rgds,
Roman (London, UK)
'92 HDJ80
