my point is has one thing alone been the problem or a part of the jigsaw
falling apart
Nobody knows the answer to that. To my knowledge no forensic engineer has ever picked over the bones of a failed 1KZTE head (like they would in the event of an airplane engine fail or something). What we have had is a series of extremely well-informed (and some not so!) amateurs or non-specialist professional mechanics come up with a series of ideas and theories. These are scattered over the internet like gold dust
The general consensus appears to be:
The cooling system is fine on the 1KZTE, but it is
marginal (although some say it is not quite good enough to sustain heavy, long-distance towing). If any element is less than perfect there could be problems.
Possible common failure points have been identified:
- viscous fan, oil leaks out of its clutch meaning it doesn't reach top operating speed when it should
- radiator, missing fins or blocked/corroded internally. ALways used Toyota red to avoid the latter, buy a decent quality replacement radiator
- thermostat can fail, the 82-degree one is fine, but some suggest the 76-degree one for long distance, hot country use or towing (although some people disagree)
-don't rely on the Toyota temp guage which won't indicate overheating until it's too late. Some people fit their own temp guages, either measuring the coolant temp or the exhaust temp
-heater pipes to the rear heater can corrode, leading to loss of coolant
-going at sustained high speed for long periods!
