springs
Hi Guys
Recently I took off the rear wheel carrier off because it was a pain in the arse having to constantly open it every time the boot space was needed and always worried if it was locked.
Im left with about 10 holes in the body work.
So anyway I have noticed a 1 and a 1/2cm difference in the level of the rear suspension.
The side the rear wheel carrier was on is lower.
Will this lost height come back up or is it gone for ever.
It does not effect anything other than I know its there.
cheers
john 92HDJ 80 1HDT
John,
That seems a bit odd, the wheel side should have been higher. Give it a
couple of weeks to see if you get used to it, if not, you can get spacers to
fit under the spring ends. Some times when I park mine it looks one side
low, other times it seems fine. I have given up noticing.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
AdBlock Detected
