hello all, looking for your expert help again...
had the lc out for some mild offroading today and now im getting a strange intermittent clunk from underneath. It resembles been still in 4wd while im trying to turn left or right on the road, feels reluctant and wound up..... have gone in and out of 4wd ranges, diff lock back and forth and no different! now i was using the 4wd and the rear diff lock and yep got rightly stuck.... but never really gave it abuse, kinda was a case of drove into a wet ditch/gully and sunk and after a small amount of wheel spinning in gloupy sandy muck i gave up and was winched out. turned off the 4wd out onto the road, travelled 30mile and found it fine, no problems. then turning left into a mates yard i had a clonk and it seemed as if it was in 4wd with centre diff locked. tried the 4wd ranges again and made a clonk when reversing and then travelled cautiously home another 20 miles and it just feels strange in the front end, grabby when turning left or right.....
ive been researching here and reading the horror front diff saga's..... firstly could it be 4wd wind up(as when stuck i jacked up the front drivers wheel only to put waffle board under and then just scrapped that idea as i got winched out) surely the wheels would have revealed themselves on the gravel i drove on after??
what should my steps be to check it out? raging as its my dd and im back to work on saturday!
i had a quick look and all dry and looks ok underneath...
will drain the front diff oil tomorrow and look for foreign objects(all diff oils changed 3 months ago) after that where do i start? pull back c.v boots and check the joints? or do i need to drop the strut and pull the shaft out for a view of this?
fingers crossed its a simple thing but loud clunky noises are never good! grrr...
as always any advice is greatly appreciated!
p.s its a 1998 lwb 3.0 manual
