Simon Rane
- Dec 17, 2019
have had a issue with starting , sometimes click noise , has new starter and relay also, still sometimes hearing click noise and starter not engaging , have seen 79 series with low voltage issue doing same thing , and solutions ? without having auto electrician bill , cheers ….. saw on YouTube 6mm wire to relay from battery for stronger signal and stronger voltage to starter solenoid and starting , best way to address low voltage to relay , ??? battery is fine also and ground wires clean contact . Problem occurs about 50 to 60% of the time when starting , pain an the arse . thanks for your time
1989 HJ75 4L 2H Diesel aftermarket turbo 7-8 pound boost "no intercooler" 3" exhaust
