Renate,
If you have the choice - and bearing in mind your comments about Michelins
or whatever. Then get split rims, they will allow you to use tyres with a
stiffer sidewall - and that is where quality is to be found. Cheap 8 spokes
or modulars look good but are not too practical on a 'real' 4WD as they
mostly have no split rim.
JB as for size of wheels, I really don't know why people want the biggest
they can fit - in Europe anyway. If you want to go rock crawling with Lal
then I can understand. But in Europe - thinking m u d - then go for
flotation i.e. width of footprint, and not even more height off the ground.
(If you are short then you can't even climb into the driving seat!) Wide
16 inch are better. Its what we use out here and we go everywhere the
peacekeeping force goes with much higher spec vehicles.
Jon
'92 HZJ80 ex UN surplus in Bosnia
Jon
