steering seal kit
Hi Guys
Does anyone know where to get an aftermarket steering seal kit.
I tried Milner but they dont do one and Mr T want over 150 euro for the
pleasuse.
Also there is a shaft that goes into the box, would this be necessary
usually to buy. This little item in Mr T is arond 380 euro.
Id like to get this shaft on a return basis if you dont use it but as is the
case with all the bits for the cruiser thay are special order, so no way.
Now before you all try to kill me I know its not possible to tell without it
being stripped down but just going on all your experience would it usually
have to be replaced at the same time as the seals.I was thinking that by the
time im 75 I will have all the bits done to the cruiser that need doing or I
want to do. Isn't life in the fast lane so quick .
cheers
john 92HDJ 80 1HDT
Hi Guys
pleasuse.
the
I
cheers
john 92HDJ 80 1HDT
