Steering spacer
Oli.g
Anyone on here make or sell steering spacers to fit a Colorado?
got a 2” bodylift but didn’t come with the spacer :grin: :disappointed:
They should have them because I made them the original pattern!
I’ve sent them an email so hopefully hear back today, it’s a 2” bodylift but the one they sel is 1.5” would this still work?
Yes because the 2" lift in the suspension isn't 2" in the steering column.
Can't remember where i got my body lift but it included a steering spacer which made steering very heavy until i loosened the spline collar bolt which was seized solid but driving around the block very slowly had it all come good so i re-tighted the collar bolt and never looked at it since . So theres adjustment to be had anyway right about where the steering spacer fits .
Yep you must slacken off the splined sections on the column or the steering will bind.
thanks lads but unfortunately back to drawing board..
milner apparently don’t supply them!:doh:
I'd ask the seller because its likely more of a job to find the material than it is to make the spacer .
Odd because there is the spacer sitting in their picture for the lift kit
70 quid is dirt cheap the steering spacer is worth that alone i would say given the headaches it avoids for you .
I should’ve bought the Milner one but I wanted the extra half inch :tearsofjoy: :tearsofjoy: :tearsofjoy:
If I was to make another one there wouldn't be much change out of £70 for sure.
