Storage solutions.
karl webster Dec 29, 2017
  1. cmcmill01
    cmcmill01 Well-Known Member Supporter I am in uk
    397
    113
    63
    Map
    Very interesting website for lots of stuff, think I would need to get under the truck and measure to see what’s the correct size.
    Would love to get Smev hob and sink mounted on some slides in a drawer system
  2. StarCruiser
    StarCruiser Well-Known Member Supporter Guru It's my birthday! I am in uk
    11,656
    4,669
    113
    Garage:
    Map
    Thought about doing that myself but talked myself out of it…for now.
  3. David
    David Well-Known Member Supporter
    1,207
    353
    83
    Garage:
    Map
    I have never been very keen on cooking inside the truck tbh so won't ever be an expense for me
  4. cmcmill01
    397
    113
    63
    Map
    My thoughts where it would come out on slides and then hinge through 90 degrees so it Wouldn’t impede access to a fridge on another slide or drawers. No idea if that would work but like the idea!!!!
    Also would have to be one one those 22” partner stoves if not the Smev combo
  5. StarCruiser
    11,656
    4,669
    113
    Garage:
    Map
    Have you been reading my mind CM? :shock::icon-idea: I've had exactly the same thoughts and reservations. I've even yet to make that drawer so I've still to decide what to do but the real hurdle was the question 'do I need it?'
  6. fbnss
    fbnss Well-Known Member Supporter I am in england
    2,693
    1,794
    113
    Map
    Need and want are two very different things :)
    StarCruiser, clivehorridge and Chas like this.
  7. StarCruiser
    11,656
    4,669
    113
    Garage:
    Map
    I know, many things pass 'Do I want it' not many pass 'do I need it'. :)
    clivehorridge and fbnss like this.
  8. StarCruiser
    11,656
    4,669
    113
    Garage:
    Map
  9. karl webster
    karl webster Land Cruiser Club sponsor Promoted Company Guru Land Cruiser Club Promoted Company
    5,489
    986
    113
    Map
    As Rich did I fitted the eberspacher under the drivers seat. I had fitted the heat exchanger under there but that's had to be moved.
    I'm refitting the heat exchanger closer to the hot water supply and shower.
  10. notsodusty
    notsodusty Well-Known Member I am in australia
    640
    452
    63
    Map
    ears my build , 105 series - was an 8 seat'a but bein single don't really need all dem extra butt rests , so now it's a 2 seater wid triton draws in da back section and me homies where da other seats used ta be .................... da duel battery is behind da passenger seat wid da 50ltr water tank next ta it , so once it's completed it'll ave da fridge on da slideoutand room ta sleep if it's to wet ta setup da rooftop tent and all other gear nicely tucked away out'a sight.
    carpets cut'n ready ta glue so still got'a bit left ta do .................................... post up da finished job later .
    lifes good .
  11. notsodusty
    640
    452
    63
    Map
    bit'a angle , grunt rubber ties'n carpet
    heaps'a room ta roll round .
  12. notsodusty
    640
    452
    63
    Map
    Finished!!! ........................... all sweet'n'cosy
    carpeted (marine) , angle attached'n no f#@%in rattles ...................... wooooohoo still plenty ta do .tank goodness fa mods.
    fbnss likes this.
  13. moggy1968
    moggy1968 Well-Known Member
    2,937
    1,309
    113
    Map
    For me accessibility is key. I found making a frame really handy so I don’t have to pull everything out to get to other stuff. The box on the right is bedding, on the left is cooking heat and food, other stuff goes on top, works a treat, now we only have to pull out what we need.
  14. Dave_S
    Dave_S Well-Known Member
    995
    338
    83
    We've something similar in the Sprinter, just using Wolf boxes. Same idea though.
  15. moggy1968
    2,937
    1,309
    113
    Map
    Cut our packing and unloading time by about an hour!!!
  16. rob rule
    rob rule Member
    159
    103
    43
    Map
    There is a logic error here - one needs to establish very accurately what you need/want first. Then, having established requirements, go about completing those exact requirements.
    Starting at the arse end by looking for "storage solutions" without a definitive requirement list is a little like walking into an off-road accessory shop with an unlimited credit card and buying all the shiny items.
    ....experience is a bad teacher......:)
    Lorin and Dave_S like this.
  17. moggy1968
    2,937
    1,309
    113
    Map
    Not for me, the sequence is more like
    Idea - build - fuck it up - build it again - realisation - build another one
    nick_the_fish, Dave_S, Chas and 3 others like this.
  18. rob rule
    rob rule Member
    159
    103
    43
    Map
    I know - not unique there :) called experience.....
  19. StarCruiser
    11,656
    4,669
    113
    Garage:
    Map
    Hence a thread sharing members experiences on what works and what doesn’t (for them at least) should be beneficial…no? :)
    grantw likes this.
  20. Øyvind Sør
    Øyvind Sør New Member I am in norway
    25
    2
    3
    Map
    I would think that lifting the floor, like notsodusty and making drawers, that way you can get things out easily, even with a full boot!
Share This Page
    Dismiss Notice
