Sorry if this has been discussed already (I searched and only found one thread), but my 1995 FJ80 is seriously leaking around the sunroof. It stormed last night, so I sat inside the truck to watch where the water enters. I watched as the trim covering the A pillars soaked and then the water began dripping from them near the bottom (I had already removed the plastic trim covering the threshold…I'd also already pulled back the carpet). It filled up the small channel near the door. It was dripping from the handle on the A pillars. It was doing this equally on both sides of the truck. I had cleaned the drain tubes earlier, as well as applied silicone on the areas that others on this forum had suggested.
I observed that my sunroof is very loose. I can push it down about 1/16th of an inch with my finger when closed. Is this normal? I'm assuming at this point that my sunroof moulding needs to be replaced. Is this something I can do myself? Is it a major pain?
I'm open to other suggestions to stop the leaking if anyone has them. Thanks in advance.
