Firewout
it's not a drama, it didn't work when I bought the truck, but I would like to get it going again.
So here's the story :
the tach gets its signal from the IP.
the signal goes to the EGR ECU and from there to the dashboard.
first I checked the ground connection. this was OK
Next I measured the signal from the IP to the ECU with a scope.
that seems to be ok, it reacts nicely when I rev the engine.
next I opened the ECU and measured the Input from the pump and the output to the dashboard.
input ok, but the output is a steady 12 volt which doesn't change when engine is revved. so maybe the ECU is toast.?
Does anyone know how the signal to the meter in the dashboard should be ? I was thinking to bypass the ECU (EGR is diconnected anyway) and route the NE+ signal directly to the meter.
Will this work or will it end in a small puff of black smoke?
all input appreciated!
