I had a look at this one: http://www.sor.com/cat255b.sori,ve already read how john fitted his but are there any other options than the direct 4x4 one. want to keep it standard as possible
Where to get hold of.What's wrong with OEM?
Does the drawing come from them as well?mayamaya has it in stock. this is the main part only:
https://www.amayama.com/en/search?region=172&q=51903-60120
It might be more expensive, but I think it's an easier install and nothing going through the body. I am weary of drilling through bodywork. Bumper plastic is another thing. I will have to save up for that, and with my health deteriorating, it will be maybe next year.That one you linked to looks smart Werner.
I tried that, but maybe I am not doing it correctly as I can't find any drawings.I have that OEM spare wheel carrier fitted to my project vehicle.
It came with the vehicle but had the Toyo-Stickers all over it.
I had to modify it to make the latch fit. The unit I got MAY have originally been intended for a J8 as here are different versions listed.
Another thing to consider, is that if You fit this unit, You must reinfore the body inside the rear quarter panel (corner) where the upper hinge attaches to the body.
In the bottom there is a bracket that slides in that bolts to the body. You drill through the outer skin & bolt the lower hinge into th bracket.
Furthermore You must shorten the body trim aft of the rear wheel arch.
The suppport that goes onto the upper tail gate is abit "hmmmm"....
You must drill through two panles (1 cavity). In an ideal world, one would reinfore this area too....
Don`t underestimate the work required.
& if You want to fit the genuine 18" rim to it, You must add abt 60mm of spacer.
Shout if You need pictures.
@werner; The drawing can be found in the parts catalouge
Me too, I'm not keen on going away from factory and drilling holes. Inside the tailgate or out of sight is an exception though.It might be more expensive, but I think it's an easier install and nothing going through the body. I am weary of drilling through bodywork. Bumper plastic is another thing. I will have to save up for that, and with my health deteriorating, it will be maybe next year.
No, it's been going on for a while now, but it is getting worse unfortunately.Me too, I'm not keen on going away from factory and drilling holes. Inside the tailgate or out of sight is an exception though.
Sorry to hear you're not well Werner. Nothing to do with me keeping you out in the cold I hope?
Hope it's soon sorted and you're on the mend.No, it's been going on for a while now, but it is getting worse unfortunately.
http://www.japan-parts.eu/toyota/gr...x/4_791350_014_/body/5153_spare-wheel-carrierDoes the drawing come from them as well?
