The 100 pads only fit on the front, and yes I did fit them.
I also did a full flush and bleed of the brake fluid so hopefully improvements all round.
Also noticed a front outser wheel bearing was very loose and quite worn - fortunately they are the same as the back and I still had a part worn one that I had replaced in the autumn so a quick swap and repack should last a while.
As usual a quick pad change and bleed took led on to revealing other issues and took 7 hours in all.
Cheers,
Julian
Home: 01285 821 712
Office: 01285 821 910
Mobile: 07971 540 362
Cheers,
Julian
Home: 01285 821 712
