So one of my new Mr-T batteries leaks a bit of "stuff" out of the vent hole. For the last month, it has also forms some corrosion around the negative terminal. Not much, about as high as a match head.
I poured some water / bi-carb on it and it's definitely electrolyte as there was lots of fizzing.
A call to my friendly parts man at Toyota to ask about this as it should be under warranty etc. He said the warranty covers dead batteries and this is probably due to over charging.
So, a quick test with meter and with the engine running, the battery is at 13.8 at idle, 14.0 / 14.1 when revving it.
Is 14v considered over charging?
Why would only one battery have a problem?
Out of interest, any reason it's the negative terminal with the corrosion? Is it a chemical / electrical thing (current flowing from positive to negative over the top of the battery / leaked electrolyte?) or is it just that that seal was weaker than the positive?
