Towball question please...
stuart j
Any else towing with a 150 LC4 please? I am struggling a bit with towball height – I tow a Brain James trailer with race car and wheels etc, about 1,500 kgs. With tow ball set at 17.5” (that’s from ground to top of towball when LC unladen), trailer is a bit too nose down when loaded. If I lift the towball by an inch or so via the drop plate, the trailer is too nose up when unladen – to the point the front wheels are off the ground! If anyone else tows a similar load on a 150 without air suspension, I’d be really grateful if you could measure the towball height – I appreciate there are regulations for this and mine seems fine in theory but the actual angle at which the trailer sits varies with suspension travel on the towing vehicle.
Many thanks
Stuart
Pedders do an airbag for the 150. It might help the sagging?
