Andrew Prince
- Feb 23, 2010
I have been removing my standard towbar in preparation for the fitment of a receiver bar. The various bolts have been fun to get off so far - years of salt and mud in an exposed position and you can guess the rest. The bolts on the chassis were a combination of captive nuts and normal nuts - getting access to the nuts inside the chassis rails were fun too the N/S chassis rail had captive nuts for all 3 bolts whereas the O/S had 1 captive and 2 normal/loose nuts.. Is this normal?
Anyway, my question is a bit more dull - is there an easy way of disconnecting the towing electrics? Without simply cutting the cable I traced the cable back into the body behind the O/S rear wheel but it then disappears up the pillar without any plugs or connectors. I do not want to fiddle around disconnecting the individual wires in the back of the plug next to the towball if at all possible - very finicky connecting them all up again and there is plenty of Lincomb mud clogging the plug up. The plug is mounted on a rusty & bent plate clamped between the towball and drop-plate - no easy way that I can see of separating the plug from the towbar...
Advice and suggestions please!
Cheers,
Cheers,
